"Log into the web application. Once you’re on the dashboard, select the division and click “Enter without Dashboard.”
"In this page, under ‘Masters’ menu, select ‘Field Force’."   
“To view the base level Vacant ID, select ‘View Vacant/Hold’ option. Then the filtered list of vacant IDs will appear by Field Force wise, User name wise, designation, HQ wise, Employee ID and State wise search mode.
Once ‘search by’ option appears, click ‘GO’. Once done, a table with list of vacant IDs will appear”.
“ This table shows the list of vacant IDs along with HQ, State, designation and doctors count for the corresponding field force. It also has four options to Activate, Edit, Rejoin and Deactivate”.
To Activate Vacant ID
“Click on the ‘Activate’ option in the list of vacant ID table corresponding to the field force, you will be redirected to the page of Field Force ID creation form where details of the field force need to be filled.
To fill the vacant headquarter, new employee details should be filled in with the options below such as Field Force name, State Name, HQ, Type, Designation, reporting to, Password, Joining Date, Reporting Start Date, Employee ID, Username and Category. Subdivision and contact details can also be given along with those details.
Once all the details are given, click ‘Submit’. Followed by it, a pop-up appears saying, ‘updated successfully’.”
To Edit Vacant ID:
“Select the ‘edit’ option in the list of vacant IDs table corresponding to the field force, you will be redirected to the page of Field Force ID creation form with the preexisting information. Here, you can edit the necessary information alone. Once all the details are given, click on the ‘Submit’ option. Following it, a pop-up appears saying, ‘updated successfully.’
To Rejoin a Vacant ID:
“Select ‘Rejoin’ option in the list of vacant IDs table corresponding to the field force, you will be redirected to the page of Field Force ID creation form with the preexisting information. Here, you can edit the necessary information alone. Once all the details are given, click ‘Submit.’ Following it, a pop-up appears, saying ‘updated successfully.’
To De-activate a Vacant ID:
“Click the ‘De-activate’ option in the list of vacant IDs table corresponding to the field force. After selecting the ‘de-activate’ option, you will automatically be de-activated of a particular Field Force ID. Following it, a pop-up appears, saying ‘deactivated successfully.’
That's how you can view the vacant ID and do the necessary edits in it.
